Sham link metrics - please help!
jigsaw2026
I am a customer who has just had a sham link set up, so that OSPF area 0 runs on both sides of the MPLS.
However, I am now getting really high metrics in the routing tables on the CEs. I need to be able to modify the vlaues so that I can load balance with another MPLS. Previously we had tunnels running between our own routers and used the ip ospf cost command on the tunnel interfaces, but this doesn't make a difference if I try it on the CEs.
Please can someone help me? Is it something that my service provider could do - i.e. set it so that the advertised metric of routes coming through either end is say 10?
Any help most definitely appreciated.
J
attrgautam
Level 5
Level 5
Leanne
Your provider can definitely help you with the metrics by setting a metric on the Sham-link itself. But iam suprised why you are unable to change the cost on the local CE interfaces ? Are you sure that it is not being reflected across the OSPF cloud ?
attrgautam
Level 5
Level 5
Leanne
Hi Gautam,
Actually yes it is working on the CEs now, I was entering the command on the serial rather than ethernet interface. I think I will just play around with the cost values until the metrics from the two MPLSs are equal.
Leanne
network.king
Level 4
Level 4
Yes , its possible and your SP can do it.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087ce2.html#wp1025241
Is that you have two connections with two providers ???
regards
vanesh k
