samarjit dutta
Beginner
SRTE ODN not working. What is the problem ?
Topology Brief
  • Three isolated IGP domains AGG-A, AGG-B, CORE running ISIS level 2 only
  • Segment routing is enabled on all IGP domains
  • CORE10 (SRPCE) running BGP-LS all border routers to learn topology from all three domains
  • For reachability between PE/PCC to SRPCE/CORE10 ibgp IPv4 is used. IPv4 bgp is running on PEs, Border routers and SRPCE. Border routers are reflecting route and updating next-hop
  • SRPCE/CORE10 propagating only its loopback 11.0.0.1/32 and suppressing all other IPv4 routes
  • PEs are maintaining VPNv4 neighborship with CORE11. CORE11 reflecting VPNV4 routes without changing the next-hop
  • PE routes are configured as PCC and maintaining peering with SRPCE CORE10
Objective:
Creating ODN tunnel from CORE7 to CORE10 for a prefix (20.200.0.1/32) attached with CORE10 (in vrf A)
Problem: BGP path is pointing towards the Attribute-set but then communication between PCC and PCE seems to be not triggering. Path showing down
Current status:
RP/0/0/CPU0:CORE-7#show bgp vpnv4 unicast vrf A 20.200.0.1
Mon Nov 18 22:37:44.249 UTC
BGP routing table entry for 20.200.0.1/32, Route Distinguisher: 100:1
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker                 28          28
Last Modified: Nov 18 22:06:02.837 for 00:31:41
Paths: (1 available, no best path)
  Not advertised to any peer
  Path #1: Received by speaker 0
  Local
    10.0.0.1 T:DEFAULT (inaccessible) from 11.0.0.1 (10.0.0.1)
      Received Label 24005
      Origin incomplete, metric 2, localpref 100, valid, internal, import-candidate, not-in-vrf
      Received Path ID 0, Local Path ID 0, version 0
      Extended community: OSPF route-type:0:1:0x0 OSPF router-id:20.13.10.1 RT:100:1
      Originator: 10.0.0.1, Cluster list: 11.0.0.1
      TE tunnel attribute-set DEFAULT, down, registered, bsid none, if-handle 0x00000000
RP/0/0/CPU0:CORE-7#show mpls traffic-eng tunnels brief
Mon Nov 18 22:46:43.822 UTC
Config
router bgp 100
 neighbor 11.0.0.1
  remote-as 100
  update-source Loopback0
  address-family vpnv4 unicast
   route-policy TEST in
route-policy TEST
  if destination in (20.200.0.0/24 le 32) then
    set mpls traffic-eng attributeset DEFAULT
  endif
end-policy
mpls traffic-eng
 attribute-set p2p-te DEFAULT
  pce
  logging events all
  path-selection
   metric igp
PCC to PCE peering
RP/0/0/CPU0:CORE-7#show mpls traffic-eng pce peer ipv4 11.0.0.1
Mon Nov 18 22:48:12.286 UTC
PCE Address 11.0.0.1
State Up
  PCEP has been up for: 02:11:32
Precedence 255
Learned through:
  Static Config
Sending KA every 30 s
Time out peer if no KA received for 120 s
Tolerance: Minimum KA 10 s
Stateful
  Update capability
  Instantiation capability
Segment Routing capability
KA messages rxed 1575 txed 1574
PCEReq messages rxed 0, txed 43
PCERep messages rxed 43, txed 0
PCEErr messages rxed 0, txed 0
  Last error received:  None
  Last error sent:  None
PCE OPEN messages: rxed 2, txed 2
PCERpt messages rxed 0, txed 11
PCEUpd messages rxed 3, txed 0
PCEInit messages rxed 0, txed 0
PCEP session ID: local 1, remote 0
Average reply time from peer: 28 ms
Minimum reply time from peer: 9 ms
Maximum reply time from peer: 299 ms
0 requests timed out with this peer
RP/0/0/CPU0:CORE-7#
From SRPCE checking valid path between CORE7 and CORE10
RP/0/0/CPU0:CORE-11-PCE#show pce ipv4 path source 7.0.0.1 des 10.0.0.1
Mon Nov 18 23:50:57.097 UTC
Path:
Hop0: 10.5.7.2
Hop1: 10.1.5.2
Hop2: 10.1.4.1
Hop3: 10.4.8.1
Hop4: 10.8.10.1
RP/0/0/CPU0:CORE-11-PCE#show pce ipv4 peer
Mon Nov 18 23:51:30.465 UTC
PCE's peer database:
Peer address: 7.0.0.1
  State: Up
  Capabilities: Stateful, Segment-Routing, Update, Instantiation
Peer address: 10.0.0.1
  State: Up
If I create a manual tunnel on CORE7 for destination CORE10. It is coming up
RP/0/0/CPU0:CORE-7#show run int tunnel-te 100
Mon Nov 18 23:56:24.155 UTC
interface tunnel-te100
 ipv4 unnumbered Loopback0
 destination 10.0.0.1
 path-option 1 dynamic pce segment-routing
Mon Nov 18 23:57:13.052 UTC
Name: tunnel-te100  Destination: 10.0.0.1  Ifhandle:0xb0
  Signalled-Name: CORE-7_t100
  Status:
    Admin:    up Oper:   up   Path:  valid   Signalling: connected
    path option 1, (Segment-Routing) type dynamic pce (Basis for Setup, path weight 50)
    G-PID: 0x0800 (derived from egress interface properties)
    Bandwidth Requested: 0 kbps  CT0
    Creation Time: Mon Nov 18 23:54:38 2019 (00:02:35 ago)
  Config Parameters:
    Bandwidth:        0 kbps (CT0) Priority:  7  7 Affinity: 0x0/0xffff
    Metric Type: TE (global)
    Path Selection:
      Tiebreaker: Min-fill (default)
      Protection: any (default)
    Hop-limit: disabled
    Cost-limit: disabled
    Delay-limit: disabled
    Path-invalidation timeout: 10000 msec (default), Action: Tear (default)
    AutoRoute: disabled  LockDown: disabled   Policy class: not set
    Forward class: 0 (not enabled)
    Forwarding-Adjacency: disabled
    Autoroute Destinations: 0
    Loadshare:          0 equal loadshares
    Auto-bw: disabled
    Path Protection: Not Enabled
    BFD Fast Detection: Disabled
    Reoptimization after affinity failure: Enabled
    SRLG discovery: Disabled
  History:
    Tunnel has been up for: 00:02:34 (since Mon Nov 18 23:54:39 UTC 2019)
    Current LSP:
      Uptime: 00:02:34 (since Mon Nov 18 23:54:39 UTC 2019)
  Segment-Routing Path Info (PCE computed path)
    Segment0[Node]: 6.0.0.1, Label: 16006
    Segment1[Node]: 1.0.0.2, Label: 17001
    Segment2[Node]: 3.0.0.1, Label: 16003
    Segment3[Node]: 9.0.0.1, Label: 16009
    Segment4[Node]: 10.0.0.1, Label: 16010
Displayed 1 (of 1) heads, 0 (of 0) midpoints, 0 (of 0) tails
Displayed 1 up, 0 down, 0 recovering, 0 recovered heads
RP/0/0/CPU0:CORE-7#show version brief
Tue Nov 19 00:08:28.586 UTC
Cisco IOS XR Software, Version 6.4.2.16I[Default]
Copyright (c) 2018 by Cisco Systems, Inc.
ROM: GRUB, Version 1.99(0), DEV RELEASE
CORE-7 uptime is 1 day, 1 hour, 14 minutes
System image file is "bootflash:disk0/xrvr-os-mbi-6.4.2.16I/mbixrvr-rp.vm"
cisco IOS XRv Series (Pentium Celeron Stepping 3) processor with 3145215K bytes of memory.
Pentium Celeron Stepping 3 processor at 2453MHz, Revision 2.174
IOS XRv Chassis
1 Management Ethernet
3 GigabitEthernet
97070k bytes of non-volatile configuration memory.
866M bytes of hard disk.
2321392k bytes of disk0: (Sector size 512 bytes).
RP/0/0/CPU0:CORE-7#
4 REPLIES 4
samarjit dutta
Beginner
One correction ....
In the explanation, by mistake i mentioned CORE11 as CORE10.
CORE11 is SRPCE and RR. CORE10 is PE
Elvin Arias
Beginner
Nice setup you have over there ;)
Please post/do the following:
1. Make sure all your links are set to P2P in IS-IS topology first, XRTC can only compute paths (return EROs) for P2P links.
2. Post the "show bgp vrf <VRF>" and "show bgp vrf <VRF> <PREFIX> detail".
Elvin
I have created one tunnel from PE1(CORE7) to PE2(CORE10) with the following CLIs. Such tunnel is up and out put of it available on original post. So I think XRPCE can find out the path between the PEs.
output of manually created tunnel
  Status:
  Config Parameters:
    Path Selection:
    Hop-limit: disabled
    Auto-bw: disabled
  History:
    Current LSP:
2ndly out put of show bgp vrf <VRF>" and "show bgp vrf <VRF> <PREFIX> detail". is very much same as show bgp vpnv4 unicast <prefix>
RP/0/0/CPU0:CORE-7#show bgp vrf A 20.200.0.1
Tue Nov 19 21:41:40.441 UTC
Versions:
  Speaker                 11          11
Last Modified: Nov 19 20:53:24.917 for 00:48:15
  Local
RP/0/0/CPU0:CORE-7#show bgp vrf A 20.200.0.1/32 detail
Tue Nov 19 21:51:45.360 UTC
Versions:
  Speaker                 11          11
    Flags: 0x00040001+0x00000000;
Last Modified: Nov 19 20:53:24.917 for 00:58:20
  Flags: 0x4000000024020005, import: 0x00
  Local
I cannot use wireshark  in this network.
Like to identify whether PE sending any message to PCE for the path towards nexthop ?
Is the attribute set triggering communication with PCE
Is there any error in negotiation with PCE and PE during requesting the path ?
