TE for VPLS customers
Hi all,
Is it possible to configure TE for individual customer, instead to forward all traffic (all customers traffic) in single tunnel. where all customers are in VPLS (l2VPN).
eg. A diagram is attached herewith for further reference : one TE tunnel for customer CE-a and same like for others customers.
Thank you.
Uttam
17 Replies 17
Please not everyone.
When using pseudowires, customer mac address's are not learned by your core mpls network.
however, in vpls, customer mac addresses are learned.  So be careful when using vpls, unless you have implemented 802.1ah
Jude Bryant
Pioneer Telephone
OK,
so I did some research.
example
Ethernet pseudowire type/mode tagged or 0x00004
(lan1)==(tagged traffic)==>{interface}PE/P[R1]{mpls cloud}[R2]PE/P{interface}==>(tagged traffic)==(lan2)
vlan 123 is not globally defined.
mac address from both lan1 and lan2 are not learned within the cloud
this is a point to point pseudowire.
router 1
lo0
ip address 10.10.10.1
interface 3/0/1
service instance 100 ethernet
encapsulation dot1q 123
rewrite ingress tag pop 1 symmetric
xconnection 10.10.10.2 100 encapsulation mpls
router 2
lo0
ip address 10.10.10.2
interface 3/0/1
xconnect 10.10.10.2 100 encapsulation mpls
the packets ingress from lan 1 is tagged with vlan123
because of this the service instance is making decisions based on matching this tagged traffic (encapsulation dot1q 123)
example
Ethernet pseudowire type/mode raw or 0x00005
(lan1)==(tagged or untagged traffic)==>{interface}PE/P[R1]{mpls cloud}[R2]PE/P{interface}==>(tagged or untagged traffic)==(lan2)
the service instances do not try to match vlan tags so we use the word default for encapsulation type.  not decisions are made.  this is raw mode
traffic in traffic out
router 1
lo0
interface 3/0/1
encapsulation default
router 2
lo0
interface 3/0/1
the packets ingress from lan 1 is tagged with vlan123 or untagged
now we can create a service instance that is not making decisions based on matching this tagged traffic (encapsulation default)
anything that comes in on this port tagged or untagged goes thru
this is similar to a layer2 tunnel, however this tunnel can be protected by a backup pseudowire..
Hoped I explained this in a clear matter.  If not please ask any questions you mave have.
Please refer to the document provided by
shivlu jain
Modes Of Ethernet Over MPLS (EoMPLS)
thanks Shivlu
and Regards
Jude Bryant
Pioneer Telephone
Hi, i have vpls with two vfi used for two different ce. I have conf two tunnel but on igp routing  table ospf one tunnel is used  as next hop for Both remote pw loopbacks and this si something i don’t want . I want the  routing through first tunnel to’ first remote pseudowire loopback and the second tunnel to be used to re ah the second remote pseudowire loopback. How  can i do ? Pleas help.
