transport mirroring traffic from one site to a remote probe
pavlosd
Explorer
Explorer
We have this new project requirement to tranfer a mirror traffic from a Location A to Location B. At location A we have a switch 3750. At location B a probe is installed (similar to wireshark). The two locations are connected suing IP/MPLS network routers (7204, 7304).
I was looking through the Cisco site for any solution and I came only across ERSPAN but this is only supported on specific models.
I was wondering if somekind of an alternative exists, using IP/MPLS services, i.e. L2 Martini Circuit.
Any ideas? Regards.
2 REPLIES 2
Atif Awan
Any ideas? Regards.
I have seen customers carry SPAN traffic across point-to-point MPLS pseudowires. You can configure the required SPAN (monitor) session on 3750 and plug the SPAN destination port to the PE router which can in turn be configured to carry SPAN traffic via EOMPLS to the remote PE which will remove the MPLS encapsulation and send the SPAN data to the probe attached to it.
Atif
RSPAN is what we had in mind testing. Thanks.
