steven.crutchley
Beginner
Two VRF to exchange routes... except default
I have two vrfs configured on my PE routers (within GNS3). The original setup is pretty simple, as follows:
ip vrf VRF_A
 rd 100:1
 route-target export 100:1
 route-target import 100:1
ip vrf VRF_B
 rd 100:2
 route-target export 100:2
 route-target import 100:2
I want these two VRFs to exchange routes, except for their default routes. As such I have done the following:
ip prefix-list blockDefault seq 5 deny 0.0.0.0/0
ip prefix-list blockDefault seq 50 permit 0.0.0.0/0 le 32
route-map ALL_EXCEPT_DEFAULT_VPN_A permit 10
 match ip address prefix-list blockDefault
 set extcommunity rt 100:10
route-map ALL_EXCEPT_DEFAULT_VPN_B  permit 10
 set extcommunity rt 100:20
ip vrf VRF_A
 rd 100:1
 export map ALL_EXCEPT_DEFAULT_VRF_A
 route-target import 100:20
 route-target export 100:20
ip vrf VRF_B
 rd 100:2
 export map ALL_EXCEPT_DEFAULT_VRF_B
 route-target import 100:10
 route-target export 100:10
Now I am finding that, even thoughI can see the routes from VRF_A in VRF_B, I am actually losing routes that were once in VRF_A from the routing table (and vica versa).
Can someone advise if I have the above configuration correct?
1 ACCEPTED SOLUTION
Rolf Fischer
Engager
Hi Steven,
the problem with your route-map is, that the "set extcommunity rt" clause without the "additive" keyword will replace all the existing RTs (100:1/100:2 as well) with the new RT.
There are several ways to accomplish the task, e.g.:
ip prefix-list DEFAULT-ROUTE permit 0.0.0.0/0
route-map ALL_EXCEPT_DEFAULT_VRF_A permit 10
 match ip address prefix-list DEFAULT-ROUTE
 ! do nothing
route-map ALL_EXCEPT_DEFAULT_VRF_A permit 20
 ! every other prefix
 set extcommunity rt 100:10 additive
ip vrf VRF_A
 rd 100:1
Result:
R1#show ip bgp vpnv4 all 0.0.0.0 0.0.0.0 | i VRF|RT
Paths: (1 available, best #1, table VRF_A)
      Extended Community: RT:100:1
Paths: (1 available, best #1, table VRF_B)
      Extended Community: RT:100:2
R1#! a prefix originated in VRF_A
R1#show ip bgp vpnv4 all 172.16.12.0 | i VRF|RT
      Extended Community: RT:100:1 RT:100:10
R1#! a prefix originated in VRF_B
R1#show ip bgp vpnv4 all 172.16.13.0 | i VRF|RT
      Extended Community: RT:100:2 RT:100:20
Rolf
3 REPLIES 3
Rolf Fischer
Engager
Hi Steven,
 ! do nothing
ip vrf VRF_A
 rd 100:1
Result:
Rolf
Also have a look at your route-map names (VPN <> VRF):
ip vrf VRF_A
Rolf
Remove and reattach the map.
CCNA Training in Marathahalli
Content for Community-Ad
