mmarchuk
Beginner
VRF routing to secondary IP addresses
I have a unique setup where clients are utilizing a multipoint radio uplink for connectivity. Their addresses are basically secondary addressing on the GigE on the 6524 switch I'm using.
Since the GigE port sees all of the traffic as if it is part of the same Layer2 connection, is there a way to separate the IP addressing on that GigE into individual subinterfaces without using VLAN ID's? I ultimately want to be able to allow each client site connected on the multipoint link to be able to participate in a VRF for that individual client's network.
1 ACCEPTED SOLUTION
n.nandrekar
Enthusiast
Hi!
It is not possible to create subinterfaces with ip addrewsses without using vlans. Vlans are the only things from dataplane perspective which de-multiplex the data to different subinterfaces.
Niranjan
2 REPLIES 2
n.nandrekar
Enthusiast
Hi!
Niranjan
adam.wilkins
Beginner
Have you considered creating tunnels between you and the three remote locations? You could associate the tunnel with the corresponding VRF.
Content for Community-Ad
