08-30-2018 11:25 PM
What do i need to turn this Features on LFA-FRR ?? i heard this feature do need user intervention to create tunnel as in MPLS-TE FRR
my core routing is OSPF
Thanks all
09-03-2018 09:34 PM
Hi Ibrahim,
Assuming you have IOS/XE you can use the following guide to enable LFA for OSPFv2.
The basic configuration for LFA FRR is as simple as activating it under OSPF through "fast-reroute per-prefix enable prefix-priority priority-level"
For remote LFA also the RLFA node computation is dynamic and no pre provisioning/configuration is required.
regards
Ashish
09-04-2018 12:30 AM
thanks bro for ur reply
09-12-2018 02:55 PM
Hello @Ibrahim Jamil
you just configure FRR under OSPF (and TE tunnels) and that's it.
perhaps you need to confirm the version you use includes LFA-FRR.
