Xconnect Problem: Unidirectional Traffic Forwarding
Hello!
I have some problem with xconnect in the follow scheme:
Cisco 6524:
interface Port-channel115.179
encapsulation dot1Q 179
xconnect 10.240.0.2 20179 pw-class PW_MPLS
end
Cisco 7606:
interface GigabitEthernet3/0/2.179
xconnect 10.240.0.4 20179 pw-class PW_MPLS
end
My problem:
When I try to ping host-2 from host-1 I get ping request timed out. I this case I can see send packets to xconnect on Cisco 6524 and receive packets on the Cisco 7606. And I have arp-entry for host 192.168.255.15 in the arp-table on host-2.
When I try to ping host-1 from host-2 I get ping request timed out too. But I haven’t send packets to xconnect on Cisco 7606 and receive packets on Cisco 6524.
How I can understand - it’s well traffic forwarding from host-1 to host-2, but nothing from host-2 to host-1.
If I did “ping mpls pseudowire 10.240.0.4 20179“ from Cisco 7606 - all ok (I can see send packets on Cisco7606).
This is "sh mpls l2 vc 20179 det" from Cisco 6524:
Local interface: Po115.179 up, line protocol up, Eth VLAN 179 up
  Interworking type is Ethernet
  Destination address: 10.240.0.2, VC ID: 20179, VC status: up
    Output interface: Gi1/31, imposed label stack {3032}
    Preferred path: not configured
    Default path: active
    Next hop: 10.2.100.204
  Load Balance: none
  Flow Label: Disabled
  Create time: 01:11:34, last status change time: 01:04:40
  Signaling protocol: LDP, peer 10.240.0.2:0 up
    Targeted Hello: 10.240.0.4(LDP Id) -> 10.240.0.2, LDP is UP
    Status TLV support (local/remote)   : enabled/not supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 160, remote 3032
    Group ID: local 0, remote 0
    MTU: local 9216, remote 9216
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  VC statistics:
    transit packet totals: receive 0, send 12
    transit byte totals:   receive 0, send 816
    transit packet drops:  receive 0, send 0
This is "sh mpls l2 vc 20179 det" from Cisco 7606:
Local interface: Gi3/0/2.179 up, line protocol up, Eth VLAN 179 up
  Destination address: 10.240.0.4, VC ID: 20179, VC status: up
    Output interface: Gi3/0/8.100, imposed label stack {160}
    Next hop: 10.2.100.4
  Create time: 01:05:39, last status change time: 01:05:39
  Signaling protocol: LDP, peer 10.240.0.4:0 up
    Targeted Hello: 10.240.0.2(LDP Id) -> 10.240.0.4
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: not sent
    MPLS VC labels: local 3032, remote 160
  VC statistics:
    packet totals: receive 6, send 0
    byte totals:   receive 408, send 0
    packet drops:  receive 0, seq error 0, send 0
In what could be the problem?
P.S. And sorry my poor English...
5 Replies 5
Sudeep Valengattil
Can you please check if the access interface counters (towards host-2) are increasing in both in/out directions, for the frames which you sent.  Also try adding a static ARP for host-1mac-address  in host-2 to see if it fixes.
Let us know the result.
Sudeep
Hello!
I don't know what I can say...
Just that magic manage network!
Host-2 is Cisco3750 with vlan-interface. Whent tried to verify the packets on your advice I created access-list TEST on Cisco7606:
Extended IP access list TEST
    10 permit ip any host 192.168.255.1 log
    20 permit ip any host 192.168.255.15 log
    30 permit ip any any
I used it in sub Gi3/0/2.179:
ip access-group TEST in
ip access-group TEST out
Then I remove ACL from sub-interface:
no ip access-group TEST in
no ip access-group TEST out
And.. magic! Ping succefull.
Then I tried repeat:
1. Remove xconnect
2. Create xconnect
3. Ping...- nothing!
3. Add ACL to sub.
4. Remove ACL from sub.
5. Ping... - works!
I repeat this method many times - it works! Why?!?!?!
I have no logical reason!
Maybe bug?
I use:
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD2a, RELEASE SOFTWARE (fc2)
Hey,
Can you please check applying ACL without "log" keyword and see if it fixes.
Sudeep
Hey, Sudeep!
I repeated this operation for ACL without "log" keyword.
All works. After I did add/remove ACL for sub - traffic forwards correctly.
Suddep, could you explain to me why this is happening?
I realy can't understand.
Konstantin.
I did one same type of LAB without subinterface friend hope u like my effort !!!!!see config
R1#sh run
Building configuration...
Current configuration : 1288 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip tcp synwait-time 5
pseudowire-class anand
encapsulation l2tpv3
ip local interface Loopback0
interface Loopback0
ip address 1.1.1.1 255.0.0.0
interface FastEthernet0/0
ip address 200.200.200.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
no cdp enable
xconnect 2.2.2.2 10 pw-class anand
interface Ethernet1/0
no ip address
shutdown
duplex half
interface Ethernet1/1
no ip address
shutdown
duplex half
interface Ethernet1/2
no ip address
shutdown
duplex half
interface Ethernet1/3
no ip address
shutdown
duplex half
router eigrp 1
network 0.0.0.0
auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
interface Loopback0
ip address 2.2.2.2 255.0.0.0
ip address 200.200.200.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
no cdp enable
xconnect 1.1.1.1 10 pw-class anand
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router eigrp 1
network 0.0.0.0
auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Though my tunnel not on with the command
sh mpl l2 vc
but my PC from R1 can ping now R2
Bye,
