3.1 pxGrid - Difference in Deployment of General Settings/Profiling
Josh Morris
Level 3
Level 3
I have a fully distributed deployment (2 PAN, 2MNT, 4 PSN, 2 PXG) on v3.1P3. Under deployment > pxGrid nodes > General Settings, I have enabled the pxGrid persona. When only the pxGrid persona is enabled, you do not get the 'Profiling Configuration' tab. But under my PSNs, I have the Profiling Configuration tab, which has pxGrid listed as a profiling service. What is the point of this profiling service? When I'm trying to connect third parties to ISE via pxGrid, should I be pointing them directly to the pxGrid modes, or the PSNs that are running the pxGrid profiling service?
Charlie Moreton
All of this information is in this rather handy ISE Profiling Design Guide
Charlie Moreton
