AAA authentication problem
ms4561
I've setup my AAA config as follows "aaa authentication login default group tacacs+ enable". When I test config with SSH (ACS turned off)to the router I cannot login using the enable password. The same does not work when trying to connect with Con0. How can I correct this problem. Forum help is much appreciated, thanks all.
m.sir
Level 11
Level 11
You have authorization only with tacacs+, can you try following command
aaa authorization exec default group tacacs+ none
M.
I agree that the configuration of aaa authentication login looks ok (I would probably use line as the alternative method instead of enable - but it should work with either) and that the issue is the configuration of authorization:
this provides no alternative method. And I suspect that if you look carefully at the error message when you attempt to login without TACACS the error is actually about authorization rather than about authentication. The suggestion of:
should be ok. I have used this way with success:
aaa authorization exec default group tacacs+ if-authenticated
Rick
Rick
