Showing results forĀ
Search instead forĀ
Did you mean:Ā
ACS 5.2 Cisco-AV-Pair Problem
Hi at all
i have a Problem with the cisco-av-pair string on the Cisco ACS and a SSID.
We  have here some SSID and some AD Groups. It was no Problem with the old  Cisco ACS 4.2. I have here configured the string: cisco-av-pair  ssid=myssid. The Clients have only rights to this ssid. It works without  Problems.
On the new ACS 5.2. I have here Problem to configure this.
My Configuration is a new Identity Policy.
Compound Condition:
Radius-Cisco -->cisco-av-pair-->equals-->myssid
But this string works not.
Did you have any ideas about this Problem.
My System:
Cisco ACS 5.2 with all new Patches
Cisco WLC newest Version
regards
Andreas
You could try a condition:
Called-Station-ID  ends-with ":0FFEN"
6 Replies 6
jrabinow
Level 7
Level 7
I think you need to match on the string that appears in the attribute. In this case. "ssid=myssid"
If you want to confirm what string should be used select: Monitoring and reports -> Launch Monitoring & Report Viewer
and then select Authentications -> RADIUS today
You should see a list of the requests including the ones you had tried. In the details column click on the icon and you will see the details of your RADIUS request. This includes the list of RADIUS attributes received. You can look at what is in the AV pair field and make sure a correct condition is specified
Hi jrabinow,
thanks for your Answer.
My Authorization Policy is with follow string:
RADIUS-Cisco:cisco-av-pair equals ssid=OFFEN
I can the in Other Attributes:
ACSVersion=acs-5.2.0.26-B.3075
ConfigVersionId=56
Device  Port=32769
RadiusPacketType=AccessRequest
Protocol=Radius
Service-Type=Framed
Framed-MTU=1300
Called-Station-ID=1c-17-d3-fc-9b-00:OFFEN
Airespace-Wlan-Id=7
Device  IP Address=10.99.11.16
OFFEN is my SSID.
In the Steps from the Report i can see:
regards
Andreas
15006  Matched Default Rule
15012  Selected Access Service -  DenyAccess
11019  Selected DenyAccess Service
11003  Returned RADIUS Access-Reject
from the steps can see that no Access Service is being matched. It is selecting the default rule.
A first step will be to look at the Service Selection Policy (Access Policies > Access Services > Service Selection Rules) and see why an access service is not being selected
I have make a Test with the "Airespace-WLAN-ID" Attribute.
I can configure a rule with
RADIUS-Cisco Airespace-Wlan-ID=7
This works. I can only connect to this Wlan-ID.
I have found this in the Other Attributes list.
ConfigVersionId=56
Device  Port=32769
Protocol=Radius
Service-Type=Framed
Framed-MTU=1300
Airespace-Wlan-Id=7
But i can not find only the name of the SSID, only in the String "Called-Station-ID..."
Is it possible that the ACS get not this Information from the WLC?
Hi Jrabinow,
thanks for your help. I have configured this condition and now it works.
regards
Andreas
