ACS 5.3 and Brocade SAN Switch Integration Problem
andrew-hunt
Beginner
Beginner
Hello all,
I am trying to use RADIUS authentication for Brocade SAN switches, specifically the HP AJ821A switch for the c-class blade enclosure.
SAN switch configuration is:
aaaconfig --add 10.180.250.222 -conf radius -s sharedsecret -a peap-mschapv2
aaaconfig --authspec "radius;local" -backup
ACS is configured with an Access Service set to PEAP with the inner method as EAP-MS-CHAPv2
Authentication works fine if set to PAP (so I know it's hitting the right service and so forth) but when it is set to PEAP I get the following error:
11818 Failed to parse EAP-MSCHAP packet
Any suggestions?  Anyone else run into this problem?  Anyone managed to get it working?
Andrew.
Dmitry Kishkin
Beginner
Beginner
Hi all. I have this problem too. May be anyone can help me ?
