10-14-2012 03:07 AM - last edited on 03-25-2019 05:29 PM by ciscomoderator
Hello guys, I am found a problem which I can't solve regarding authorization with using Identity Groups in Access Policy rule.
ACS version: 5.3.0.40.6 (internal build B.839)
I have very simple RADIUS Authorization rule which authorize user on behalf of right Identity Group.
When I will try login with my testing user then authentication against RSA SecurID is OK, but authorization will be denied by Default rule – It looks like my Rule with Identity Group is totally omitted.
I am managing several other ACS servers (version 5.3 but with older patches) where similar rules are working without problem.
What I am tested:
Do you have any idea where problem can be?
10-17-2012 02:04 AM
OK guys, it started working yesterday without any configuration change. Maybe it was some database inconsistence wich was solved by ACS itself.
