ACS 5.3 replication problem
Lajja1234
Hi!
My two ACS 5.3 servers are configured to replicate between the primary and the secondary. They stopped replicate for about a month ago and I want to check the logs, but I cannot find any logs that says anything about the replication? Can somebody tell me where they should be?
/Lajja
Shaoqin Li
Level 3
Level 3
get the support bundles.
Jatin Katyal
You need to look into management logs of ACS.
Here are the steps:
acs/acsadmin# acs-config
Escape character is CNTL/D.
Username: xxxx ( GUI ADMIN USERNAME)
Password: xxxx ( GUI ADMIN PASSWORD)
acs/acsadmin(config-acs)# debug-log mgmt level debug
Exit
Show acs-logs filename ACSManagement.log
Note: Once you collect the above fine. Turn off the mgmt logs with this command
           debug-log mgmt level warn
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
