Highlighted
Beginner
ACS 5.5 Primary and secondary hardware requirement for distributed system
I have a situation where I need to upgrade ACS 5.1 to 5.5 which running under VM environment. On Primary server I have less amount of space on internal file system, need to add more space for that volume. My question is that, if I add let's say 100 GB on primary, do I need to add same amount on secondary to make it identical? Appreciate your help.
Thanks!
1 REPLY 1
Highlighted
 Instance running log
Instance running log collector should have 500 Gig rest can be 100Gig. Running log collector on instance less then 500 will cause critical issue.
~JG
Do rate helpful posts
