02-05-2013 11:05 PM - edited 03-10-2019 08:03 PM
Hi there
we have two ACS 5.0.4.46.1 and since a few weeks, it reports the following error:
I stopped and restarted ACS, reconfigured the repository, reconfigured the backup and so on. I even rebooted the ACS but it sill has this problem. Did anyone ever have this problem and how did you resolve it? I can see "Please contact TAC..." but I first wanted to ask the community.
Thanks in advance and best regards
Dominic
02-11-2013 01:58 AM
Hi Dominic,
I also received this kind of message in addition of other messages which indicate that purge has been successfully done.
Did you open a case about this behavior ?
Vincent
02-11-2013 02:03 AM
Hi Vincent
I did not open a TAC case, but I did the following test last week: I removed the installed patch 5-4-0-46-1.tar.gpg and voilà, we don't get the error message anymore. At the moment I will not update to 5.4.0.46.1 again, I just let it work like that.
If you have installed the patch, try this and send me a short update.
Best regards
Dominic
02-11-2013 02:05 AM
Thanks for your response Dominic ! I'm running ACS 5.3 patch 8, maybe there is the same problem in this patch. I will surely wait for the patch #9.
Thank you.
02-11-2013 04:41 AM
There is in fact a CDETS open for this
CSCue35765: invalid alarm show: DBPurge is not running for the past two days
According to the CDETS description:
- the purge itself is in fact running OK
- a restart of the system stops the alarms from occuring (although this contradicts information at the start of this thread although I guess that need to restart the M&T node)
Have not seen this confirmed from other sources
02-11-2013 04:52 AM
Hi jrabinow
thanks for the Bug ID. I did try to restart both ACS (primary and secondary [secondary is also M&T]) but in my case this did not help. But as I can see, the bug only occurs in patch 1 of 5.4, so this would correlate with my post, that removing the patch 1 did solve the problem.
Dominic
02-13-2013 10:53 PM
Understood and I passed this information on. Two items of good news here:
- This issue will be fixed in patch 2 which should be available by end of month
- All indications are that is an issue of incorrect notiifcation rather than the underlying purge not being performed. However, do understand that this may mask real alarm notifications
02-19-2013 09:14 AM
patch 2 was posted today and includes a fix for this issue
