ACS Serial problem
scott-goodwin
I have 2 ACS SE.
However i cannot connect to the serial console on either of them, I have checked the settings and they are definatley correct.
I was able to connect to them upon install btw.
Also if i reboot them i get all the bios boot info then nothing, no prompt etc..
Do I need to enable something to make this work again??
Any ideas??
Thanks Scott
8 Replies 8
Jagdeep Gambhir
Level 10
Level 10
It seems that you did not follow the correct upgrade procedure. What software ver you upgrade it to? Did you run csupdate first?
Hi Scott
I have the same problem, but this has nothing to do with an upgrade like jgambhir said.
I would also welcome some help.
Dominic
Dominic,
Which console cable did you use to connect? Make sure you are using cisco blue cable and DB9 connector.
This issue is also caused by incorrect cable type.
~JG
Do rate helpful posts
Please check the following settings
Establishing a Serial Console Connection
Before you can perform the initial configuration of ACS SE, you must establish a serial console connection to it. This procedure requires a PC, two DB-9 to RJ-45 adapters (provided), an RJ-45 cable (provided), and terminal emulation communication software (Hyper Terminal or equivalent).
To establish a serial console connection:
Note If you performed the procedure in Connecting Cables, you can skip to Step 2.
Step 1 Connect a console to the serial console port on the back panel:
a. Attach a DB-9 to RJ-45 adapter (provided) to the serial port of the console.
b. Attach a DB-9 to RJ-45 adapter (provided) to the serial port of the ACS SE. For the location of the serial port, see Figure 1-3.
c. Use an RJ-45 cable (provided) to connect the console to the ACS SE.
Tip You may also use a serial concentrator connection, if desired.
Step 2 Power on ACS SE and the console, and open your terminal emulation communication software on the console.
Tip See Figure 1-2 for the location of the power switch on ACS SE.
Step 3 Set your terminal emulation communication software to operate with the following settings:
•Baud = 115200
•Databits = 8
•Stops = 1
•Flow control = None
•Terminal emulation type = ANSI
Result: The login: prompt appears.
If after this you are unable to have console access I will suggest to apply the console patch that will fix any console issue.
You can get this patch with TAC.
Hi erdelgad
sorry I didn't see your answer. Is this a special patch or is it integrated in the cumulative patches for the 4.2.124.x ACS?
Thanks a lot.
The cable you should use is a db9 to rj45 conversion piece and then on the other end you can use a regular console cable.
It is a special patch for this kind of issue but the only way to get this patch is throw TAC.
Hi JG
thanks, but I use the blue console cable from cisco and also the db9 connector, which was included in the acs engine box.
I tested with the "official" settings and also with any other combination of speed, parition and so on, but that didn't help.
Can you plug in the monitor to appliance and see what output you are getting?
