ASDM Privilege Level default 15 for Radius users
John LeCoque
So this may be a bit of a dumb question...
I stumbled upon an ASA today that is configured to authenticate against a Radius server for SSH and HTTPS connections. If I log in via SSH, I can't gain a privilege level of more than 1 (tried login command, etc).
However, if I log in with ASDM, I always have privilege level 15.
Command authorization is not enabled.
Is this default behavior. If so, why? Do I need to enable command authorization to override this behavior?
FYI, the system in question is running ASA 8.3(1)
Thanks much
shekharmore003
Can you please provide the AAA configuration
aaa-server RADGR protocol radius
aaa-server RADGR host 10.2.2.2
timeout 4
key cisco123
aaa authentication enable console RADGR LOCAL
After logging in, use the enable command with your user password.
http://www.cisco.com/en/US/partner/docs/security/asa/asa83/configuration/guide/access_management.html#wp1145571
Jatin Katyal
In ASA you can't land directly to privilege exec mode after enetring your login password. You have to enter the enable password too. This is only designed for IOS where you can  directly land to( # ) by-passing the enable passowrd mode.
Jatin Katyal
- Do rate helpful posts -
~Jatin
