Brazil power cord for SNS3515?
slevesqu
There is no power cord available for Brazil in the CCW configurator. I can see different SKUs being mentioned like
CAB-ACBZ-12A
CAB-ACBZ-10AWhich one is appropriate for SNS3515s to be deployed in Brazil?
1 ACCEPTED SOLUTION
kegagnon
Sylvain,
You should see a Brazil power cord come up in the CCW configuration for the 3515 and 3595 either tomorrow or the next day.
Best Regards, Kevin
3 REPLIES 3
Kasun Bandara
VIP Advocate VIP Advocate
VIP Advocate
use below link to find-out correct matching cable for your country regulations and the port which fix with the device power outlet.
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C260/install/C260/portcabl.pdf
Good luck
KB
kegagnon
Sylvain,
Best Regards, Kevin
Thanks Kevin as always!
