Cisco AP's and VoIP phones using Certificates with ISE 2.4
mitchp75
I'm trying to find good documentation around how to configure ISE and the Switch and/or a WLC to authenticate a Cisco AP using the Manufacture Installed Certificate on the AP and not MAB. Is there a best practice or any experiences others can share? Equally important I want to do the same thing with Cisco Phones, is there anything different there?
Mitch
Nidhi
2 ways to go about this.
You can have a copy of root CA certificate that signed the phone certificate in ISE and have a policy in ISE to validate the attributes in certificate to authorize the phone.
Secondly, you can enable 802.1x on phone. by default, I believe its not enabled. Add the certificate in trusted certificate store.
Create certificate authentication profile (CAP) to check for CN ( Administration- Identity Management- external identity store) and then create identity sequence and reference the CAP created in screen below. You can then create a 802.1x authentication policy to check for certificate fileds.
EAP-TLS authentication for WLC is explained here-https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213543-configure-eap-tls-flow-with-ise.html
Nidhi
For MIC with ISE authentication, check these two videos which are very
useful. They cover what you are looking for and more :)
http://www.labminutes.com/wl0006_wlc_access_point_authentication_1
http://www.labminutes.com/wl0006_wlc_access_point_authentication_2
For Phones, here is a good resource.
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/TrustSec_1-99/IP_Tele/IP_Telephony_DIG.html
**** Please remember to rate useful posts
We were able to get the Cisco VoIP phone to authenticate via 8021.x EAP-TLS by swapping Certs for each system: Importing the Call Manager Certificate into the ISE trusted store, providing the ISE Certificate to the Call Manager which then gets pushed to the phone.
