Cisco ISE 2.3 - Docker Daemon not running
Y4ssine
Hello everyone.
When I checked the application status of ISE, I saw that the Docker Daemon service was not running:
ISE-01/admin# show application status ise
ISE PROCESS NAME                       STATE            PROCESS ID
Database Listener                      running          24205
Database Server                        running          74 PROCESSES
Application Server                     running          29726
Profiler Database                      running          26075
ISE Indexing Engine                    running          31533
AD Connector                           running          1260
M&T Session Database                   running          25977
M&T Log Collector                      running          29865
M&T Log Processor                      running          29776
Certificate Authority Service          disabled
EST Service                            disabled
SXP Engine Service                     disabled
TC-NAC Service                         disabled
Wifi Setup Helper Container            disabled
pxGrid Infrastructure Service          disabled
pxGrid Publisher Subscriber Service    disabled
pxGrid Connection Manager              disabled
pxGrid Controller                      disabled
PassiveID WMI Service                  disabled
PassiveID Syslog Service               disabled
PassiveID API Service                  disabled
PassiveID Agent Service                disabled
PassiveID Endpoint Service             disabled
PassiveID SPAN Service                 disabled
DHCP Server (dhcpd)                    disabled
DNS Server (named)                     disabled
ISE-01/admin#
After doing a stop and start of the ISE application I saw following error:
ISE-01/admin# application start ise
Starting ISE Monitoring & Troubleshooting Session Database...
Starting ISE Profiler Database...
su: warning: cannot change directory to /home/iseprofilerdb: No such file or directory
/bin/chown: cannot access â/home/iseadminportal/.keystoreâ: No such file or directory
/bin/chmod: cannot access â/home/iseadminportal/.keystoreâ: No such file or directory
Starting ISE Application Server...
Starting ISE Monitoring & Troubleshooting Log Processor...
Starting ISE Monitoring & Troubleshooting Log Collector...
Starting ISE Indexing Engine...
su: warning: cannot change directory to /home/iseelasticsearch: No such file or directory
Starting docker daemon ...
Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xe" for details.
WifiSetup is disabled.....
Starting ISE AD Connector...
Note: ISE Processes are initializing. Use 'show application status ise'
      CLI to verify all processes are in running state.
ISE-01/admin#
Is there anyone who already encountered this and knows how to get it running again ? This is the first time I see it in not running state.. However I haven't noticed something yet that isn't working properly due this.
Version we're running on:
# show version
Cisco Application Deployment Engine OS Release: 3.0
ADE-OS Build Version: 3.0.3.030
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2014 by Cisco Systems, Inc.
All rights reserved.
Hostname: ISE-01
Version information of installed applications
Cisco Identity Services Engine
Version      : 2.3.0.298
Build Date   : Tue Jul 25 19:02:37 2017
Install Date : Mon Aug 28 12:38:57 2017
Cisco Identity Services Engine Patch
Version      : 3
Install Date : Mon Jul 16 07:27:19 2018
ISE-01/admin#
Thanks a lot for taking a look into this and I'm looking forward to your replies.
Kind regards,
Yassine
Yassine
Junior Network Engineer
Jason Kunst
The docker not starting is likely because you’re not using the wireless setup. This is only needed for those using secure access wizard
https://community.cisco.com/t5/security-documents/cisco-ise-secure-access-wizard-saw-guest-byod-and-secure-access/ta-p/3636602
Some more information as well - https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/admin_guide/b_ise_admin_guide_23/b_ise_admin_guide_23_chapter_010.html?bookSearch=true
Startup process behavior per release
2.2 and patch 1 - started by default
2.2 patch 2 - service disabled user directed via UI to enable in the CLI
2.3/2.4 - service disabled user directed via UI to enable via UI or CLI
If you’re experiencing an outage resulting to this then please open a tac case. Not sure about the profiling or other errors
Jason Kunst
