09-04-2018 01:15 PM
I am building a cisco ise 2.4 vm, this is only for 1000 nodes just using tacacs authentication (1 to 1 replacement for ACS)
Has anyone set this up to use fewer than 12 core? It just seems like alot.
Solved! Go to Solution.
09-04-2018 01:35 PM
09-04-2018 01:35 PM
09-04-2018 02:50 PM
The CPU count does matter because ISE uses that to detect the system it is running on and does some resource allocation on it. For example, if you go with 6 CPU and 12k MHz, ISE will think the system is a 3415. This was the whole reason for the CPU correction in the OVAs.
09-04-2018 04:23 PM
09-04-2018 04:31 PM
