CISCO products and TACACS+
shailesh.pawar
Which are the cisco products that supports TACACS+ ?
Also please tell me about logging mechanism for that cisco products, that means where TACACS+ stores log etc.
Thanks in advance...
vikasyad
Tacacs+ is a cisco proprietary. All cisco devices support Tacacs+   including Cisco Switches,Routers,ASA,ACS,etc. Presently ISE doesn’t  support Tacacs+ but it is on the roadmap and will start supporting from  ISE 2.0 which will release later next year.
minkumar
Hi Shailesh,
  What is the end objective? If you could elloborate on it
Minakshi (do rate the helpful posts )
pavan.gokarn
Unfortunately there are many Cisco products that do not support tacacs+, take ISE for instance. The product specs should tell you if it does or not and it will also tell you the roadmap of the particular product.
Sent from Cisco Technical Support Android App
