Console CatOS MOTD small problem
vos123
I have a small problem when connecting to a console port.
We make a connection via a terminalserver to the console port of a 6500 (Tacacs+). I like to have a banner before I login on CatOs. The problem with a MOTD is that only the banner is shown after a logout.
Any suggestions?
Greetings.
Jeroen
smalkeric
Level 6
Level 6
Use the option of telnet which will show the message when you login,
set banner ?
motd Set message of the day
telnet Set telnet banner
for some reason, this doesn't work for console access. It does work for direct telnet access.
Maybe there is some problem with remote access via a terminalserver to the console port. Do i have to change something on the line (TTY) ports of the terminalserver?
switch> (enable) set banner telnet ?
disable Suppress the default Cisco Systems Console banner
enable Display the default Cisco Systems Console banner
