CSACSE-1113-K9 login problems
echelon360
Just purchased the above mentioned and i can't get into the appliance.
-Upon successful boot-up,i'm prompted with the "lock notice" capture asking me to either connect via serial or web.
-I've tried to console in the appliance using the provided serial cable but i just can't seem to get anything.It's just a blank screen.
Can someone pls pt me in the right direction?
Thanks!
somishra
Can you check the settings for the terminal software connected to the console.
The settings are :
.Baud = 115200
.Databits = 8
.Parity = N
.Stops = 1
.Flow control = None
That did it, i was using the old 9600 baud setting (i've used that for all of my cisco devices). This was one of the things i should have paid more attention to from the start.
thanks again!
cool...
rate me if it helped :)
