Diagram/Flow chart depicting communication between ISE and AD
Aditya Gupta
Hi All
Is there any reference to a diagram or a flow chart depicting communication between Cisco ISE and AD.
We need this to present as use case to Customer's infosec team.
Aditya Gupta
Jason Kunst
Did you see this?
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/install_guide/b_ise_InstallationGuide23/b_ise_InstallationGuide23_chapter_0110.html
Jason Kunst
Did you see this?
paul
Level 10
Level 10
In addition to what Jason said, unless you are talking Passive ID, ISE is simply a member device in Active Directory just like a Windows workstation or server.  If they have a diagram or understanding of how a member workstation or server communicates with AD then they have an understanding of how ISE does it.
Aditya Gupta
Thanks Paul and Jason
Aditya
