Endpoint PC with posture redirection less deep dive process work flow
Da ICS16
Dear Community,
We use ISE 3.1 with LAN wired-dot1x (PC) and wired-dot1x MAB.
We use posture posture redirection less for check complaint status ( auth.C, auth.Z ).
We want to draw diagram process work flow with low level ( deep dive ) with below points.
1. PC connect switch (EoL) - using Ad user + password credential
2. Switch (port not opened )connect to ISE
3. ISE integrate with AD ( validate Ad user authentication )
4. ISE send infor to swtich (port open: when passed Ad user + machine certificate)
5. Endpoint PC become status complaint or pending
Switch: low impacted mode
Can you advise for detailed step by step from PC start authentication until get status Compliant?
It would be good if have document support / sample process flow.
Thanks for your supporting.
