01-28-2022 11:20 PM - edited 01-28-2022 11:22 PM
So i have integrated FMC and ISE. now I'm going to use PxGrid Mitigation in my Correlation Policy and this error shows up in my FMC Health.
EPS Remediations currently in use will not work with the current pxGrid connection to ISE. Please change your correlation policy to use ANC Remediations.
how can i fix this guys im using it for Quarantine and unQuarantine users.
Solved! Go to Solution.
01-29-2022 01:54 AM
check below thread and suggestions :
https://community.cisco.com/t5/network-access-control/eps-remediations-not-work/m-p/4499851
01-29-2022 01:54 AM
01-29-2022 04:05 AM
I'm not a 100% sure about this but I think you can't use the old EPS in this case as you have FMC version 7.0.1 and ISE 3.0, and I think you should move to ANC for remediation which is the replacement module for EPS.
