incompatibility issue - WLC 5508 and ACS 5.4
Augustgood
This is my scenario:
Cisco WLC 5508 firmware 7.4.110.20 and ACS 5.4, two WLAN eap/tls, many client  can't connect to WLAN and on ACS i receive the following error:
Authentication failed : 11051 RADIUS packet contains invalid state attribute
workaround:
1 -Check the network device or AAA Client for hardware problems.
2-known RADIUS compatibility issues.
3-Check the network that connects the device to ACS for hardware problems
there are some incompatibility issue between WLC and ACS ? the compatibility matrix document for wireless imposes the 7.5 firmware for WLC.
What do you think is possibile ?
Are there any other errors shown in the details of the failed authentication?
We may need to look at service logs in debug mode, opening a TAC case would be the best way to go about this.
Javier Henderson
Cisco Systems
solved the customer has changed the certificates....:)
