01-27-2014 01:19 PM - edited 03-10-2019 09:19 PM
This is my scenario:
Cisco WLC 5508 firmware 7.4.110.20 and ACS 5.4, two WLAN eap/tls, many client can't connect to WLAN and on ACS i receive the following error:
Authentication failed : 11051 RADIUS packet contains invalid state attribute
workaround:
1 -Check the network device or AAA Client for hardware problems.
2-known RADIUS compatibility issues.
3-Check the network that connects the device to ACS for hardware problems
there are some incompatibility issue between WLC and ACS ? the compatibility matrix document for wireless imposes the 7.5 firmware for WLC.
What do you think is possibile ?
01-28-2014 05:52 PM
Are there any other errors shown in the details of the failed authentication?
We may need to look at service logs in debug mode, opening a TAC case would be the best way to go about this.
Javier Henderson
Cisco Systems
02-05-2014 02:43 AM
solved the customer has changed the certificates....:)
