again, I have an issue with ACLs and this time it is related to mab webauth redirection (Guest Portal).
Logs shows that the connection in pending due to posture status (that's OK), My dACL is applied and... nothing else.
I mean Web traffic does not get redirected.
(Auth policy mab if user not found continue)
See attached files.
webauth.jpg : AuthZ policy
webauth1.jpg : AuthZ profiles
webauth.jpg : live authentication
This is my switch port config is :
interface FastEthernet1/0/3
description test GUEST MAB
switchport mode access
ip access-group ACL-ALLOW in
authentication order mab
authentication priority mab webauth
authentication port-control auto
mab
ACLs :
ip access-list extended ACL-ALLOW
permit ip any any
ip access-list extended redirect
deny udp any eq bootpc any eq bootps
deny udp any any eq domain
deny ip any host 192.168.6.10
permit tcp any any eq www
permit tcp any any eq 443
