08-15-2018 07:40 AM
Hi all
Currently have Hotspot setup on our cisco ISE going to our WLC.
Redirect and Authentication appears to be working fine, however after accepting the EUP on a mobile device it gets stuck on "Connection Successful" page.
Anyone else experienced this or know how to sort it?
Many thanks
Solved! Go to Solution.
08-20-2018 09:38 AM
That typically happens when the guest ACL that is assigned to the guest endpoint does not allow access to ISE node. Easy fix would be to allow access from the guest endpoint to ISE node post authentication.
08-15-2018 11:56 AM
08-20-2018 06:28 AM
It just says sucessfully connected however there is no connection and gets stuck on that page.
I have found a work around though by putting in a post access banner in to say "Welcome" they click continue then it goes to connection sucessful
this then allows them network access
if i do it without, it gets stuck on connection successful with no Internet access
08-20-2018 09:38 AM
