08-06-2018 06:07 PM
If I had a Dollar each time a customer asked me "can ISE enforce traffic quotas on my Guest portal?"
I normally tell them to go buy ClearPass instead ... lol. Just kidding. But seriously, in the enterprise environment I think that option is not too far from the truth.
It's sad that ISE doesn't do much with Radius Accounting. I would argue that the next killer application in ISE should be quota processing for the Guest use case. I know we don't discuss road map on these forums, so I don't expect an answer.
However, what are the practical next steps for a customer who has invested heavily in ISE and Cisco WLC, when confronted with this requirement? What does one tell them to do?
Solved! Go to Solution.
08-07-2018 12:06 AM
Hi Arne,
This is not supported
But the best thing to do is to reach out to ISE Product Management team via your sales channel to raise a feature request.
Nidhi
08-07-2018 12:06 AM
Hi Arne,
Nidhi
08-07-2018 02:53 PM
Is this a common request in other parts of the world? Perhaps one day there will be ubiquitous uncapped internet plans, but the reality is that a lot of service providers are incapable or unwilling to change.
Feature request may never happen and I don't see anyone jumping on the bandwagon. What are the realistic steps one could take to implement such a scheme? I am thinking of some third party product that someone may have perhaps used in the past?
There are a lot of custom/bespoke systems that run on open source wireless router platforms but it's small scale. The only enterprise solution I have seen so far is Aruba Clearpass - I have not used this feature in Clearpass myself but I will evaluating it soon. It can do everything ISE can do and in this SMB space it fulfils that specific need.
08-08-2018 05:46 AM
ISE can sent WLC attributes to control guest bandwidth per user. That doesn't set a hard quota, but does limit their bandwidth consumption. Will that not suffice?
08-08-2018 06:23 PM
Hi @paul - this is probably the best we can do in lieu of a quota management system. If you throttle the bandwidth of a session then you can make it unpleasant enough for anyone wanting to potentially use it for anything other than reading their emails.
The wireless guys will argue that (in a high density environment mostly), if someone wants to download a 20MB file for example, it's better to let them download it as quickly as possible to free up the airwaves. But in less dense environments it's probably a moot point.
