ISE INTEGRATION WITH HUAWEI AC WIRELESS CONTROLLER
PQR
I am looking for some documentation on the integration between Cisco ISE and the Huawei AC wireless controller to validate compatibility, on the side of Huawei I found the following link:
https://support.huawei.com/enterprise/en/doc/EDOC1000113779/19cc124/example-for-configuring-8021x-authentication-web
But on the side of Cisco I can't find anything that indicates that ISE is compatible with Huawei AC, in fact in the compatibility matrix there is no Huawei vendor
With the Huawei link I have tried to integrate it with ISE, but it has not been possible, it does not authenticate the user, ISE rejects the authentication request packets.
Please your support with this request
howon
If you have a setup of Huawei WLC and ISE that we can look at, I can assist. Please unicast me @ howon@cisco.com.
thomas
If Huawei uses RADIUS or TACACS, it will work with ISE - we just haven't tested it.
Please see Does ISE Support My Network Access Device? for details.
If ISE rejected the authentication request, there will be an error and reason in the ISE LiveLog Authentication details that will help you understand Why it was rejected:
howon
I hope this message finds you in good health. I am reaching out to discuss a matter concerning Huawei WLC and Cisco ISE. Specifically, I have encountered an issue pertaining to the compatibility between Cisco ISE version 3.x and Huawei wireless version AC6605-26-PWR: V200R019C00SPC500 (WLC). I would like to inquire whether these two versions are compatible with each other.
Thank you for your attention to this matter, and I look forward to your prompt response
