Ldap para administracion de Switches catalyst 3850 o 9300
yabelcn
Buen día, he leído varios foros en donde dicen que prácticamente es imposible configurar un servidor Ldap y usarlo para acceso a los switches como metodo de administracion, aunque las fechas son de hace varios años ya, entonces me gustaria saber si alguien tiene informacion fresca respecto a este tema, o si a la actualidad aun no se puede utilizar ese protocolo como metodo de autenticacion a los switches .
2 Accepted Solutions
Greg Gibbs
Cisco switches, like most other vendors, cannot interact directly with an LDAP server for authentication of device administrators. The switch would need to be configured for authentication/authorization against a TACACS+/RADIUS AAA server (like Cisco ISE) which would use the LDAP/AD server as an external identity store to authenticate and authorize the admin users. This has been common practice for over a decade and is unlikely to change.
For ISE, you can find more information and examples in the Cisco ISE Device Administration Prescriptive Deployment Guide
thomas
We also have many guides about ISE LDAP support @ https://cs.co/ise-guides#LDAP
Greg Gibbs
-- From Google Translate --
"Good morning, I have read several forums where they say that it is practically impossible to configure an Ldap server and use it to access the switches as a management method, although the dates are from several years ago, so I would like to know if anyone has fresh information regarding to this topic, or if at present this protocol still cannot be used as an authentication method for switches."
Greg Gibbs
thomas
