05-13-2014 02:32 PM - edited 03-10-2019 09:42 PM
I´m running the migration Utility on a windows server 2003 that has a ACS 4.2.0.124 but i received the error:
Select the ACS 4.x Configuration groups to be migrated:[1]
1 - ALLObjects
2 - AllUsersObjects
3 - AllDevicesObjects
4 - SharedCommandSet
5 - SharedDACLObject
6 - MasterKeys
7 - SharedRACObjectWithVSA
The following object types will be extracted:
Network Device Groups
Network Device
Choose one of the following:
1 - AnalyzeAndExport
2 - Import
3 - CreateReportFiles
4 - Exit
Exception in thread "main" java.lang.NumberFormatException: For input string: "
32"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at com.cisco.nm.acs.mgmt.migration.networkdevice.NetworkDeviceExporter.c
reateAAAClientType(NetworkDeviceExporter.java:481)
at com.cisco.nm.acs.mgmt.migration.networkdevice.NetworkDeviceExporter.a
ddToImportCollection(NetworkDeviceExporter.java:186)
at com.cisco.nm.acs.mgmt.migration.networkdevice.NetworkDeviceExporter.e
xportObjects(NetworkDeviceExporter.java:117)
at com.cisco.nm.acs.mgmt.migration.MigrationApplication.executeExport(Mi
grationApplication.java:440)
at com.cisco.nm.acs.mgmt.migration.MigrationApplicationCLI.runExport(Mig
rationApplicationCLI.java:617)
at com.cisco.nm.acs.mgmt.migration.MigrationApplicationCLI.main(Migratio
nApplicationCLI.java:266)
C:\MigrationUtility\migration\bin>
05-19-2014 11:54 PM
Hey,
Which ACS 5 version are you upgrading to?
Could you share the migration.log file?
Rate if Useful :)
Sharing knowledge makes you Immortal.
Ed
06-01-2014 05:54 PM
Hi Guys, sorry for delay.
I´m migrating for version 5.5 and my 4.2 is a large database.
The migration.log is attached. I can see the error below:
06-01-2014 21:46:28 UserExporter.checkValid(UserExporter.java:233) INFO - Detected as external authenticated user. Password reset to preference setting. : 93825082
Any ideas for help me ?
Thanks.
06-02-2014 12:19 AM
Hey,
This is because users with an external password are migrated but a dummy password is migrated over.
You will need to change the password type to whatever DB you want later after migration.
Rate if Useful :)
Ed
06-02-2014 09:58 AM
Hi, ED.
I believe that i have another problem.
When i try run the option on the migration utility.
1 - ALLObjects or 3 - AllDevicesObjects
I received the error below:
32"
Any idea ?
Thanks a Lot.
06-04-2014 02:11 AM
When you run the 1 - ALLObjects or 3 - AllDevicesObjects, could you collect the migration.log again and attach it?
Rate if Useful :)
Ed
06-04-2014 06:17 AM
06-05-2014 05:55 AM
I performed new tests and the error on log now is:
06-05-2014 09:49:39 JavaUtils.isAttachmentSupported(JavaUtils.java:1308) WARN - Unable to find required classes (javax.activation.DataHandler and javax.mail.internet.MimeMultipart). Attachment support is disabled.
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:GPRS_ENG NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:GPRS_OMR NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:IPRAN_Roteadores NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:Telco_ENG NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:SCE_ENG NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:SCE_OMR NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:IPRAN_Cisco NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:IPRAN_Alcatel NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:Service_ActCRQ311961 NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:IPMUX NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:GMCArsitec NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:TS_OMR NDG has shared key password
06-05-2014 09:49:52 NDGExporter.checkValid(NDGExporter.java:122) INFO - Network Device Groups:Servidores_OMR_BKP NDG has shared key password
06-09-2014 09:39 AM
Is a generic message which is of no use.
Should not be a show stopper, it should still let you know migrate.
Do you still get this:
32"
Rate if Useful :)
Ed
05-20-2014 07:10 AM
check
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-5/migration/guide/migration_guide/Appendix_D_Troubleshooting.html
10-30-2014 10:20 AM
i have issue , i migrated database from ACS 4.2 to 5.5 but some object didnt migrated.
Some record are not in ACS 5.5 , it is missing . How to solve this and to i manage to restore complete database as it is to ACS 5.5 .
Lets same ne thing that didnt restored are rules for users that link users and dynamic acl and so on
VZ
