[Q] Whats the difference between BYOD Devices and Registered Devices?
pethomas
Hi Guys
I have a 2.1 ISE installation where we are trying to understand what is the difference between the BYOD Endpoints count on the Home -> Summary page and the count of Registered Devices in the End Point Identity Group (from Endpoint Identity Group List -> Registered Devices).
BYOD Devices - 45884
Registered Devices - 92966
As this installation purely serves a BYOD environment I would have thought we'd get a similar count. Any insights?
Peter
Craig Hyps
Advocate
Advocate
As name would imply, a BYOD device is one that has been through the NSP or My Devices Portal onboarding process.  It is possible to be assigned to RegisteredDevices group even without going through the NSP flow or MDP registration process.  It may also be the case that BYOD device was unregistered and not removed from RegisteredDevices group.
Craig
Craig Hyps
Advocate
Advocate
Craig
Thanks for the pointers Craig.
Cheers
Peter
thank you
Recognize Your Peers
