Question ISE lab Help~!!
tim.huang83
I am new and trying to setup a Lab for ISE.
I had download the ISE 1.2 and installed in VMware but after I finished install.
It doesn't show up type setup to initialize the ISE. and I try to connect the login page with its ip address. but it doesn't work. but I can ping that ip address.
Please help.
Here you have to type setup instead of login
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
When you said install it means that you typed setup on the localhost prompt?
If yes can you log in with the credentials you setup on ssh?
If yes can you do show application status ise and drop the screenshot on the forum?
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
Am I missing some steps? Please help.
Francesco
I think I find out the problem.
I used VMware 12. When I create a VM, I used typical which give me less step and that will cause the ISE installation missing some steps and it looks like install successfully but it miss the last setup step.
Ok. When you startup ISE for the 1st time, all basic config is done by issuing setup command on the 1st login screen instead of typing any account,
Francesco
