re-authentication for Wired Dot1x
parmsing
Hi Team,
Currently I am working with the customer who had deployed wired dot1x in their environment, As they have some of the switches which does not support IBNS 2.0 they are currently going ahead with IBNS 1.0 implementation at this point.
We have FlexAuth implemented for the customer with re-authentication enabled. Here is the interface configuration snip from the switch.
switch(config-if)# switchport access vlan <X>
switch(config-if)# switch access voice <X>
switch(config-if)# switchport mode access
switch(config-if)# authentication event fail retry 0 action next-method
switch(config-if)# dot1x pae authenticator
switch(config-if)# authentication port-control auto
switch(config-if)# spanning-tree portfast
switch(config-if)# authentication control-direction in
switch(config-if)# authentication order mab dot1x
switch(config-if)# authentication priority dot1x mab
switch(config-if)# ip access-group ACL-PRE-AUTH in
switch(config-if)# authentication open !!!!!Used for Monitor Mode
switch(config-if)# authentication violation restrict
switch(config-if)# dot1x timeout tx-period 10
switch(config-if)# authentication periodic
switch(config-if)# authentication timer reauthenticate server
SWITCH(config-if)# authentication timer inactivity server dynamic
switch(config-if)# authentication host-mode multi-domain
switch(config-if)# mab
switch(config-if)# authentication event server dead action reinitialize vlan CRITICAL_VLAN
switch(config-if)# authentication event server dead action authorize voice
switch(config-if)# authentication event server alive action reinitialize
when the reauth timer expires (60 minutes) our Dot1x windows machines are dropping into the default MAB Authz policy which is a known issue. As per the flexible auth document , “if you do perform reauthentication, reauthentication always returns to the first method (MAB).”
We can use Cisco AV Pair = “termination-action-modifer=1” to instruct switch to use the last successful method. This does not seems to work with Catalyst 2960X running Version 15.2(6)E1.
Also I did not find much information for the same on Cisco documents. As this is not supported by some devices. We enabled Advance settings for the supplicant, which seems to fix this issue, Below is a screenshot of the group policy config that does seems to fix the issue.
<Please refer the attachment>
I would like to ask for your advice, should we suggest customer to proceed with the above settings for supplicants “advance security settings enabled” or do we have any other workaround which can force switch re-authentication to use dot1x for dot1x capable devices?
Appreciate  your assistance on this,
Thanks and Regards,
Parm
bern81
I run into the same nightmare with order mab dot1x   and priority dot1x mab by facing intermittent loops especially if you get authenticated with mab, then after few minutes the endpoint sends eapol start packet.
As an advice use order dot1x mab.  if you are afraid of DHCP timeout, you can reduce the dot1x tx timeout period to lets say 4 sec , like this after maximum 12 sec if shifts to the next method if the first fails.
Also put the reauthenticate timer to higher value than 60 min.
I hope this helped, knowing that this is not exactly your question :)
Thanks Mate,
Yes reversing order is another option but I was wondering is changing advance settings for dot1x is going to address this issue permanently or temporarily and if this is suggested by ISE Team.
Parm
