SXP Scaling for SNS-3655 (All personas on same node)
Istvan Matyasovszki
Hi all,
Are there any SXP scaling numbers available for SNS-3655 running ISE 2.4+ when the respective nodes are deployed in standalone mode with all personas running on the same node (2xSNS-3655 redundant in total) ? The latest BRKSEC-3432 does not mention anything related to this use case.
Is it recommended to run SXP in a setup with 2xSNS-3655 standalone+redundant nodes or should one rather deploy a hybrid solution (PAN and MnT running on same node and PSN with SXP on separate node) instead even if redundancy is sacrificed ?
Thank you
Istvan
Jason Kunst
Have you checked prior BRKSEC past 2 years? it hasn’t changed. The one from CLMEL 2019 should be good with a large deck of slides
I’ll also bring this up to the SME to fix at http://cs.co/ise-perf-scale
We will be updating the information once we have the data available.
Nidhi
Recognize Your Peers
