05-08-2019 03:05 AM
Hi everyone,
Please may you assist me on how I would propagate SGT's between my FTD 2120 and Catalyst 2960X in the segment I highlighted in the attached snippet.The 2960X switch is classifying the traffic and the FTD 2120 should be enforcing the SGT policy.The challenge in propagation is that the 2960X supports SXP and does not support in-line tagging and the FTD supports in-line tagging, pxGrid and does not support SXP.
Jay
Solved! Go to Solution.
05-08-2019 03:54 AM
05-08-2019 03:54 AM
06-28-2019 01:15 AM
Sorry for the delay.My environment does not have ISE at the moment so i used your second suggestion "Alternatively put a ISR/ASR router between the 2960X and the FTD, peer the 2960X with the router to distribute the SGT bindings and then in-line tag from the router to the FTD" and everything worked out fine.
Thanks a lot
