ashirkar
Level 7
Level 7
    Introduction:
    In normal routing i.e. in Unicast routing packet forwarding decisions are typically based on the destination address of the packet arriving at a router. The unicast routing table is organized by destination subnet and mainly set up to forward the packet toward the destination.
    In IP multicast routing, the router forwards the packet away from the source to make progress along the distribution tree and prevent routing loops. The router's multicast forwarding state runs more logically by organizing tables based on the reverse path, from the receiver back to the root of the distribution tree. This process is known as reverse-path forwarding (RPF).
    In short, Incoming multicast packet will not be accepted/forwarded unless it is received on an interface that is the outgoing interface for unicast route to the source of the packet.
    Configuration Example:
    In below example multicast server S1 sends a multicast packet, with R1 flooding it to R2 and R3.R2 received its copy, and floods it as well. As a result R3 receives the same packet from two routers:
    a) On its interface fa0/0 from R1.
    b) On its interface s0/0 from R2.
    Topology Diagram:
    Without the RPF check, R3 would forward the packet it got from R1 to R2, and vice versa, and begin the process of looping packets also with the same logic, R1 and R2 also keep repeating the process. This duplication creates multicast routing loops and generates multicast storms that waste bandwidth and router resources.
    Before I dive into multicast configuration, let me share with you the initial configuration of our network. All relevant configurations are below.
    R1
    R2
    R3
    hostname R1
    ip cef
    ip multicast-routing
    interface FastEthernet1/0
    ip address 1.1.1.1 255.255.255.0
    ip pim dense-mode
    interface FastEthernet0/0
    ip address 10.1.1.1 255.255.255.252
    ip pim dense-mode
    speed 100
    full-duplex
    interface FastEthernet0/1
    ip address 10.1.1.5 255.255.255.252
    ip pim dense-mode
    speed 100
    full-duplex
    router eigrp 1
    network 1.1.1.1 0.0.0.0
    network 10.1.1.0 0.0.0.255
    no auto-summary
    hostname R2
    ip address 10.1.1.2 255.255.255.252
    ip pim dense-mode
    speed 100
    full-duplex
    interface Serial0/0
    ip address 10.1.1.9 255.255.255.252
    ip pim dense-mode
    clock rate 2000000
    router eigrp 1
    no auto-summary
    hostname R3
    ip cef
    ip address 10.1.1.6 255.255.255.252
    ip pim dense-mode
    no ip route-cache
    no ip mroute-cache
    speed 100
    full-duplex
    ip address 3.3.3.3 255.255.255.0
    ip pim dense-mode
    ip igmp join-group 239.1.1.1
    interface Serial0/0
    ip address 10.1.1.10 255.255.255.252
    ip pim dense-mode
    no ip route-cache
    no ip mroute-cache
    clock rate 2000000
    router eigrp 1
    network 3.3.3.3 0.0.0.0
    no auto-summary
    When R3 performs the RPF check the following things will happen:
    1) R3 examines the Source address of each incoming packet, which is 1.1.1.1.
    2) R3 determines the reverse path interface based on its route used to forward packets to 1.1.1.1
    In our case R3's route to 1.1.1.1/24 is matched, and it is lists an outgoing interface fa0/0, making fa0/0 R3's RPF interface for IP address 1.1.1.1
    R3#sh ip route | beg Gate
    Gateway of last resort is not set
         1.0.0.0/24 is subnetted, 1 subnets
    D       1.1.1.0 [90/156160] via 10.1.1.5, 02:01:51, FastEthernet0/0
         3.0.0.0/24 is subnetted, 1 subnets
    C       3.3.3.0 is directly connected, Loopback0
         10.0.0.0/30 is subnetted, 3 subnets
    C       10.1.1.8 is directly connected, Serial0/0
    D       10.1.1.0 [90/30720] via 10.1.1.5, 04:24:40, FastEthernet0/0
    C       10.1.1.4 is directly connected, FastEthernet0/0
    R3#sh ip rpf 1.1.1.1
    RPF information for ? (1.1.1.1)
    RPF interface: FastEthernet0/0
    RPF neighbor: ? (10.1.1.5)
    RPF route/mask: 1.1.1.0/24
    RPF type: unicast (eigrp 1)
    RPF recursion count: 0
    Doing distance-preferred lookups across tables
    R3#sh ip mroute | beg Interfac
    Interface state: Interface, Next-Hop or VCD, State/Mode
    (*, 239.1.1.1), 00:38:46/stopped, RP 0.0.0.0, flags: DCL
    Incoming interface: Null, RPF nbr 0.0.0.0
    Outgoing interface list:
       Loopback0, Forward/Dense, 00:38:46/00:00:00
       FastEthernet0/0, Forward/Dense, 00:38:46/00:00:00
       Serial0/0, Forward/Dense, 00:38:46/00:00:00
    (1.1.1.1, 239.1.1.1), 00:00:26/00:02:37, flags: LT
    Incoming interface: FastEthernet0/0, RPF nbr 10.1.1.5
       Loopback0, Forward/Dense, 00:00:26/00:00:00
       Serial0/0, Prune/Dense, 00:00:26/00:02:34, A
    3) R3 compares the reverse path interface fa0/0 on which multicast packet arrives .If they match, it accepts the packets and forward it; otherwise ,it drops the packet .In this case ,R3 floods the packets received on fa0/0 from R1 but it ignore the packets received on s0/0 from R2.
    Verification:
    1) To verify we will be sending ICMP echo to group 239.1.1.1 from R1 with source 1.1.1.1.It's always safe to collect debugging logs in buffer rather than on console hence we will be debugging multicast packet and collect it in logging buffer as shown below:
    R3#conf t
    Enter configuration commands, one per line. End with CNTL/Z.
    R3(config)#logging console informational
    R3(config)#logging buffer 7
    R3(config)#logging buffer 64000
    R3(config)#no ip cef
    R3(config)#end
    *Mar 1 04:44:41.670: %SYS-5-CONFIG_I: Configured from console by console
    R3#debug ip mpacket
    IP multicast packets debugging is on
    R1#ping 239.1.1.1 source 1.1.1.1
    Sending 1, 100-byte ICMP Echos to 239.1.1.1, timeout is 2 seconds:
    Packet sent with a source address of 1.1.1.1
    Reply to request 0 from 10.1.1.6, 24 ms
    Reply to request 0 from 10.1.1.6, 128 ms
    R3#sh logging | beg Log
    Log Buffer (64000 bytes):
    IP(0): s=10.1.1.5 (FastEthernet0/0) d=239.1.1.1 (Serial0/0) id=19, ttl=254, prot=1, len=100(100), mforward
    IP(0): s=10.1.1.1 (Serial0/0) d=239.1.1.1 id=19, ttl=253, prot=1, len=104(100), not RPF interface
    IP(0): s=10.1.1.5 (FastEthernet0/0) d=239.1.1.1 (Serial0/0) id=20, ttl=254, prot=1, len=100(100), mforward
    IP(0): s=10.1.1.1 (Serial0/0) d=239.1.1.1 id=20, ttl=253, prot=1, len=104(100), not RPF interface
    IP(0): s=1.1.1.1 (FastEthernet0/0) d=239.1.1.1 (Serial0/0) id=20, ttl=253, prot=1, len=100(100), mforward
    IP(0): s=1.1.1.1 (Serial0/0) d=239.1.1.1 id=20, ttl=252, prot=1, len=104(100), not RPF interface
    From the above logs we can see that R3 forwarded the packets received on fa0/0 from R1 but it ignore the packets received on s0/0 from R2.
    2) Let’s look it same with mtrace from R1 and capturing packet with the help wireshark on  R3’s interface Fa0/0 and S0/0.
    R1#mtrace 1.1.1.1 3.3.3.3 239.1.1.1
    Mtrace from 1.1.1.1 to 3.3.3.3 via group 239.1.1.1
    From source (?) to destination (?)
    Querying full reverse path...
    0 3.3.3.3
    -1 10.1.1.6 PIM  [1.1.1.0/24]
    -2 10.1.1.5 PIM [1.1.1.0/24]
    -3 1.1.1.1
    On R3’s interface fa0/0 we capture trace route query and request as mark in black box below diagram:
    Let's open the traceroute request packet to get more detail inside view.
    As show in above figure “FORWORDING CODE: NO_ERROR” field shows that after the router receives a multicast packet it performed an RPF check as the RPF check succeeds, the packet is forwarded.
    Now let’s view capture taken on interface S0/0:
    It is only showing trace route query not request as packets are drop due to RPF check failure.
    Hence conclusion is the RPF check is a strategy by which router accept packets that arrives over the shortest path and discard those that arrive over longer routes and thereby avoid routing loops and duplication.
    Related Information:
    IP Multicast
    IP Multicast Technology Overview
    Configuring IP Multicast Routing
    Timothy Chan
    Thanks, nice article with images and wireshark captures!
    ashirkar
    Level 7
    Level 7
    Hello Tim,
    Thanks for your positive feedback.Keep on sharing your views and knowledge on community.
    Ashish Shirkar
    Technical community manager (Network Infrastructure)
    Amjad Abdullah
    Thanks Ashis for the doc.
    ashirkar
    Level 7
    Level 7
    Welcome Amjad,Hope it helps you
    Ashish Shirkar
    MahmoudAshoor
    Awesome Explanation.  Thanks Ashish
    chris_cheng
    Community Member
    Fantastic explanation. RPF is clear now. Thanks Ashish!
    Balaji Murthy
    Hi Ashish,
    Very simple and clear explanation,
    able to understand easily and quickly in one reading.
    Thanks for sharing the knowledge :)
    Balaji.M
    nice article with Snaps , Thank you
    Sameer T
    Very good explanation..
    Thank you so much...
