Networking
Collaborate with peers and Cisco on all aspects of your network, including Cisco Digital Network Architecture (DNA), routing, switching, and more.
Don't miss this Cisco Catalyst 8000 offer
Browse the Community
Cisco Catalyst Center
This community is for technical, feature, configuration and deployment questions. For production dep...
NFVIS Solutions
Join peers and Cisco experts to discuss Cisco’s Network Function Virtualization (NFV) products and s...
SD-WAN and Cloud Networking
Join this community to interact with your peers and Cisco about SD-WAN and all things related to sec...
Switching
ThousandEyes
Join us for information about our use cases, common troubleshooting, discussions, getting started gu...
Activity in Networking
CDP/LLDP Neigbor Details
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
Setting a GRE tunnels between a NAT to a public IP.
Hi everyone.. i have been looking through multiple posts on the forum for similar cases but have not found the answer Im looking for.. I've been primarily using this thread for guidance. https://community.cisco.com/t5/networking-knowledge-base/settin...
jonmo2578 by Level 1
  • 34 Views
  • 1 replies
MTU for SVL
Is it necessary to change the MTU for SVL links in a scenario in which interfaces are configured with MTU larger than default 1500 bytes?Traffic could flow between chassis through SVL links in a Stackwise Virtual cluster. Could not find any reference...
ckuwajima by Level 1
  • 86 Views
  • 3 replies
Resolved! Windows Server NPS and Cisco Catalyst Login
Hello, I am attempting to configure a Windows Server with the NPS role to permit admins to log into our Catalyst switches using standard AD credentials.  I've got things setup per a few different guides I've looked over, but on each login attempt the...
Unsolicited CALL-HOME-DETAIL and CALL-HOME-TRACE messages
Greetings,I have a Catalyst 3650 (IOS-XE 16.9.4) that is sending a ton of unsolicited messages to the console. These don't look like Syslog messages. Can anyone tell me how to get this to stop? The switch has been cleared (del vlan.dat, wri era, relo...
jim_r by Level 1
  • 293 Views
  • 11 replies
slow data transfer rate between vlans using pbr
hii have cisco 6500 series core switch and facing a bizarre issue with data speed transfer.I have two vlans svi for which is defined on this switch (core6500). these vlans are transported to another switch (sw5) via lacp etherchannel which is providi...
Wonxie by Level 1
  • 92 Views
  • 4 replies
Puzzling results when pasting in ACL config to switch
Hello, I was creating 2 decently large ACL's to match some traffic today and I noticed something peculiar that has me puzzled. My first ACL has approx 90 ace's and pastes them fine. When I go back and look at the ACL, it looks like there are only lik...
confusion over route selected from routing table
Packets received by the router from BGP enter via a serial interface at 209.165.201.10. Each route is present within the routing table. Which interface is used to forward traffic with a destination IP of 10.10 10 24?People are saying that the answer ...
Garegin88 by Level 1
  • 96 Views
  • 6 replies
Unable to ping between two tunnel points
Hello, I built using the packet tracer a simple topology of three routers with ospf routing. I created a tunnel between the two routers that are not physically connected to each other, but I can't ping between one end and the other. I managed to ping...
Access Points show 0 clients
DNAC Installed Version: 2.3.5.5-70026Cisco Catalyst 9800-80 17.9.4aAXE 9120i, 9130We have about 10 employees in our office using DNAC at varying role assignment levels.I am Super-Administrator and handle most of the the WIFI related tasks. Of all the...
jtpntx by Level 1
  • 100 Views
  • 2 replies
IPv6 ping not working when pinging other LAN
I configured the simple network below to test the connectivity of the ipv6 in the devices. The configurations are as shown and ipv6 unicast-routing is enabled. When pinging from Router 5 to Router 6 G0/1, it succeeds but when pinging from Router 5 to...
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 149 Views
  • 4 replies
vManage SDWAN PCAP scripting help.
Good morning all!I am working on a project on our SD-WAN. I am new to SDWAN and vManage and was asked to look into possibly scripting some packet captures over a period of time. Our SDWAN consists of several IR1101's and they can only be managed via ...
DNA 2.3.3.5 - EoX Status
Hi. I was wondering if you could help me with a query I have regarding the new version of DNA 2.3.3.5. And it is that, since I updated to this new version in a DNA in production, in the inventory part it shows me a new column of "EoX Status” If I pu...
Share your Expertise
Level up by answering questions in your area of expertise.
