04-03-2015 05:11 AM
Hi all!!! There is a problem with reports exports in csv, pdf formats.The report is divided into several csv or pdf files with max number of rows in the file - 15 000 rows. Can be done to a report generated by a single file (csv or pdf) without limiting the number of rows?
At the 2.0 the csv file was about 20mb per day big. Now at 2.2 i get csv.zip file with the size of about 4mb, and in the zip file there are about 8-10 csv files with about 2-3mb. I have looked in csv file, there are now only exact 15 000 rows.
Is this changed?
04-06-2015 03:32 AM
What ideas? Does not anyone come across this problem????
04-10-2015 06:05 AM
I have got the same error at our 2.2 Version.
04-22-2015 07:38 AM
That does seem to be a change between PI 2.1 and 2.2.
You basically have to combine those CSV files to re-create a full report.
