2 headset/2 mic does not work
My friend and I play Black Ops 4 with split screen, we both have headsets.
Although we can both hear the game, only one of us can hear the team chat and chat.
Is there any way we can make both the headset and the microphone work?
Thanks all of you,
Apparently yes with the headset plugged in:
Activated both controllers, controller 1 goes to account A, controller 2 goes to account B. Then plugged the headset into each controller (or via USB, setting it to account A or B which is using it)
Then press ps on controller 1 setup, a party leave it open. return to game
Now press PS on controller 2, go to the party section and you will see controller 1's party joined.
Then in the party options set it to Party Priority, Game Sound to Party.
After that go to the party section and you will see Controller 1's party, join it.
Then in party options set it to party priority, game sound to party and try to reconnect it after reset with the help of mic test then it is working fine.
Mark Elsen
       - Is there any cisco-equipment involved ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Georg Pauwen
