2960X LED Status in CNA
RJ Riemensnider
CNA 5.8.9.1 and now CNA 6.0 allow me to administer 2960X switches but I am not getting LED status on them.
22 Replies 22
That answer is final, they are working on it internally so there is no public visibility into their progress.  The feel I got from the conversation was that it wasn't a priority, after all this has been an issue for at least a year.
RJ Riemensnider
Well it looks like 6.3 fixed the LED status on 2960X switches.  Still issues with communities and auth into CCO but the LEDs are now displaying correctly.
Sorry but it works only for the 48 ports.  On the 24 ports, the LED are still all OFF.  Next release may be it will be OK for all the 2960X models.
Can you provide exact PIDs for 2960X that work correctly (in 6.3, previously was not working) and which does not work in your network? Thank you.
Working: WS-C2960X-48FPD-L in 6.3 not in 6.2
Not Working: WS-C2960X-24PD-L in 6.2 and 6.3
SW: 15.0(2A)EX5-UNIVERSALK9
In version 6.3 it seems that 4506-e is not supported anymore!?
Please let me know what are the issues with communities / auth that you experience and if you are already aware of any bug that describes it / had a chance to speak about it with Cisco TAC. Thank you!
Cisco Network Assistant Version 6.3 have some bugs.
1. In port security it can't delete learned mac address.
2. In inventory it does not shows some versions of ios, e.g. WS-C2960-48TC-L    12.2(55)SE11          C2960-LANBASEK9-M
3. Error "WS-C4506-E is not supported in the community".Worked on CNA 6.2.
Who is responsible repair it?
