2SW-L3 not passing vlan information eachother
GabrielNoiraGT
Hi, i curretly studying networks, and i have a problem in cisco packer tracer, so i have 2 sw l3 in vtp mode server, in one sw i configure vlan, and the other are not reciving the vlans./ (vlan 10, 20 99), vtp mode server same domain, same pass, mode trunk, channel group mode trunk.
they pc have dhcp and they are ok.
1ºpic is left sw
2ºpic is right sw
ps: i'm portuguese
and i have another problem pc's, can't ping router 0.
where the show run files.
hostname SW-L3-1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip dhcp excluded-address 172.30.10.101 172.30.10.254
ip dhcp excluded-address 172.30.20.101 172.30.20.254
ip dhcp excluded-address 172.30.99.3 172.30.99.254
ip dhcp pool Visitantes
network 172.30.10.0 255.255.255.0
default-router 172.30.10.254
dns-server 8.8.8.8
ip dhcp pool funcionarios
network 172.30.20.0 255.255.255.0
default-router 172.30.20.254
dns-server 8.8.8.8
ip dhcp pool gestao
network 172.30.99.0 255.255.255.0
default-router 172.30.99.254
dns-server 8.8.8.8
ip routing
spanning-tree mode pvst
spanning-tree vlan 10,99 priority 24576
spanning-tree vlan 20 priority 28672
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
no switchport
ip address 172.30.100.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/2
switchport access vlan 50
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
shutdown
interface FastEthernet0/6
shutdown
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
switchport port-security violation protect
channel-group 1 mode active
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan50
description vlan para portas desligadas
mac-address 00d0.583c.5e03
no ip address
shutdown
router eigrp 1
network 172.30.100.0 0.0.0.3
auto-summary
ip default-gateway 172.30.100.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.30.100.1
ip flow-export version 9
access-list 99 permit 172.30.99.0 0.0.0.255
access-list 99 deny any
line con 0
password 7 0822455D0A16
login
line aux 0
line vty 0 3
login local
transport input ssh
line vty 4
login
line vty 5 14
login
line vty 15
login
end
hostname SW-L3-2
dns-server 8.8.8.8
dns-server 8.8.8.8
ip dhcp pool gestao
dns-server 8.8.8.8
ip routing
spanning-tree vlan 20 priority 24576
spanning-tree vlan 10,99 priority 28672
no switchport
ip address 172.30.101.2 255.255.255.252
duplex auto
speed auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 00e0.8f1d.7801
ip address 172.30.10.254 255.255.255.0
interface Vlan20
mac-address 00e0.8f1d.7802
ip address 172.30.20.254 255.255.255.0
interface Vlan50
mac-address 00e0.8f1d.7803
no ip address
shutdown
interface Vlan99
mac-address 00e0.8f1d.7804
ip address 172.30.99.254 255.255.255.0
router eigrp 1
network 172.30.101.0 0.0.0.3
auto-summary
router ospf 1
log-adjacency-changes
network 172.30.101.0 0.0.0.3 area 0
ip default-gateway 172.30.101.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.30.101.1
no cdp run
line con 0
login
line aux 0
line vty 0 3
login local
transport input ssh
line vty 4
login
line vty 5 14
login
line vty 15
login
end
hostname Router_Mirandela
ip cef
ipv6 unicast-routing
no ipv6 cef
username admin privilege 15 secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
license udi pid CISCO1941/K9 sn FTX15249OUC
ip domain-name TuaTerra.pt
interface GigabitEthernet0/0
ip address 172.30.100.1 255.255.255.252
ip nat inside
duplex auto
speed auto
ip address 172.30.101.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
switchport mode access
switchport nonegotiate
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Serial0/1/0
ip address 172.30.102.1 255.255.255.252
ipv6 address FE80::1 link-local
ipv6 address 3001:AB1::1/64
ipv6 eigrp 1
ipv6 enable
ipv6 ospf 1 area 0
clock rate 2000000
interface Serial0/1/1
ip address 172.30.103.1 255.255.255.252
ipv6 address FE80::3 link-local
ipv6 address 3003:AB3::1/64
ipv6 eigrp 1
ipv6 enable
ipv6 ospf 1 area 0
clock rate 2000000
interface Vlan1
no ip address
shutdown
router eigrp 1
eigrp router-id 1.1.1.1
network 172.30.102.0 0.0.0.3
network 172.30.103.0 0.0.0.3
router ospf 1
router-id 1.1.1.1
network 172.30.102.0 0.0.0.3 area 0
network 172.30.103.0 0.0.0.3 area 0
network 172.30.100.0 0.0.0.3 area 0
ipv6 router ospf 1
router-id 1.1.1.1
ipv6 router eigrp 1
no shutdown
ip nat inside source list 12 interface GigabitEthernet0/1 overload
ip default-gateway 172.30.103.2
ip classless
access-list 12 permit 172.30.10.0 0.0.0.255
access-list 12 permit 172.30.20.0 0.0.0.255
access-list 12 permit 172.30.99.0 0.0.0.255
line con 0
login
line aux 0
line vty 0 3
login local
transport input ssh
line vty 4
login
line vty 5 14
login
line vty 15
login
end
solve need to include on eigrp or/and ospf network of each vlan (in sw-l3)
luis_cordova
Hi @GabrielNoiraGT ,
Could you compress your exercise (with Winrar, for example) and attach it to review the settings?
Ola @GabrielNoiraGT ,
Você poderia comprimir seu exercício (com o Winrar, por exemplo) e anexá-lo para rever as configurações?
saudações
Where (password is cisco for secret and enable)
mode some alterations in ports (+portchanells) and i put vlans manually in the other switch (gave erros inconsistency) then e restart program and buff, problem solve.
still can't ping the first router,
