3750 48-P-S showing bad power supply
joshipiyush
I am seeing bad power supply on one of the stack 3750 switches. Please can someone confirm what needs to be done. I did check the BUG information and the version is upto date. Please see at the bottom
#sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT INITIALIZED
SYSTEM TEMPERATURE is OK
System Temperature Value: 19 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts--- ------------------ ---------- --------------- ------- ------- -----
1A C3KX-PWR-715WAC DTN1602K0J5 OK Good Good 715/0
1B C3KX-PWR-715WAC DTN1629K3AJ OK Good Good 715/0
2A C3KX-PWR-715WAC DTN1629K3AV OK Good Good 715/0
2B C3KX-PWR-715WAC DTN1602K0HA No Input Power Bad N/A 715/0
Switch Ports Model SW Version SW Image
1 54 WS-C3750X-48P 15.0(2)SE9 C3750E-UNIVERSALK9-M
* 2 54 WS-C3750X-48P 15.0(2)SE9 C3750E-UNIVERSALK9-M
Feb 2 13:58:28.108 UTC: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Feb 2 14:04:01.554 UTC: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Feb 2 14:09:33.432 UTC: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Model number : WS-C3750X-48P-S
Further Problem Description:
A similar problem occurs with SNMP traps that is noted in CSCui31295. That defect is resolved in 15.0(2)SE5 and later.
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?
(21)
Details
Last Modified:
Jan 2,2021
Status:
Fixed
Severity:
2 Severe
Product:
(1)
Cisco Catalyst 3750-X Series Switches
Known Affected Releases:
(2)
15.0(2.0.80)SE
15.0(9.8)EMP
Known Fixed Releases:
(11)
15.2(4.0.64a)E
15.2(4.0)ST
15.2(1.27)PSR
15.2(1.26)PSR
15.2(1.25)PSR
15.2(1.24)PSR
15.2(1.1)EY
15.2(1)EX0.44
15.0(2)SE2
15.0(2)EZ
Leo Laohoo
First step is a visual inspection to determine if this is a false alarm or not.
Hello Leo,
yes i have asked onsite engineer to visit the site and check the power cables.
i will post here the results
Piyush
 - Basically what should be checked is the green power led indicator on both power supplies  of the switch.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
thank you, I will ask the person onsite to confirm that.
