3825 ethwic card
maniqwils
I have a cisco 3825 that I have finally got an IOS 15.1 image for and managed to go to my local electronic recycling place and got a ethwic 4esw for this so I can maybe setup a link aggregation between my switch and modem but the router is saying that particularr ethwic is not supported or disabled in that slot. Do I have the wrong card or do I need to activate the ethwic or something. I'm new to using ethwics.
marce1000
 - Ref : https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/data_sheet_c78-660124.html
           Check Table 2 , looks like your device is not supported
 M.
is that the card depicted in the link below ?
https://www.router-switch.com/cisco-hwic-4esw-datasheet-pdf.html
The 3825 is rather old, I don't remember how many NIM slots it has in the back, but try all available slots. There are often requirements such as 'the module only goes into slot 0).
After changing the slot, reboot the router and check if the card is recognized.
