09-16-2019 12:42 PM
Hi Guys,
Is there any devices for Cisco Products or other vendor that can do 4 unit devices w/ Same IP Address of 172.17.1.1?
Or is there any devices that can do a Port Forwarding for these 4 unit devices w/ same IP if 172.17.1.1?
I am not sure how to make this work as per requirement of our customer.
Thanks in advance.
Erwin
09-16-2019 12:56 PM
Not sure what device you have or looking.
you can same IP address in a different segment of the network, that is possible you can do NAT with other IP range
09-17-2019 07:11 AM
Hi Bandi,
Thanks for the response.
Is that doable if we use a Cisco Switch 6500 That can do NAT or Port Forwarding and connect those 4 Devices w/ the same IP Address(172.17.1.1) to it?
09-17-2019 08:31 AM
09-17-2019 01:06 PM
yes possible technically.
10-03-2019 01:24 PM
10-07-2019 07:24 AM
Hi Giovanni,
thanks for the response. Is there any specific device that do VRF's? A Firewall or Layer 3 Switch?
Also, for each VRF should have it's own ISP correct?
Erwin
